Mini 0807
What is?
@ Pkentavr how you make it display this ? This is the information of your car battery . We only need it when user has problem .
I pressed display button(one long and one short click)
What is Standby Mode, and how do you get the camera into Standby mode
Page 7, section A of instruction manual, says "when camera is in standby, long press UP button for 2 seconds to enter the menu.
it seems that this is within a split second of attaching it to power, sometimes if i time it right I can get into the menu but most of the time I cant.
Surely its not this hard to access the menu?
FWIW i dont have any problem accessing playback menu by pressing down.
@blake7
The menu can always be reached as soon as the cam is supplied with power.
Probably the switch is very sensitive and detects both, push up and sideways simultaneously.
That happens to me often in the setting because I rotated 180 ° in "Flip Mode" use the Cam.
Hi Joy.
My mini 0807 was broken.
My mini is periodically frosen, at work.
I changed the SD card, the problem remained.
During operation, the recorder turned off.
The last video was not saved.
Now the recorder does not turn on.
How can you help?
I sent message to you e-mail.
standby means not recording, stop recording to enter standby mode then you can get to the menu etc
Hi, I don't know if this is the right place to communicate but I just installed my new 0807 and ihe red light on the sos button flashes when it is in use. Is this right?
Hi Joy.
How can you help?
My situation is resolved.
I bought the Camera in August 2016 on the website gearbest.сom
The camera stopped turning on in May 2017.
He contacted the support of gearbest, they needed a seal on the camera.
I removed the seal when I adjusted the focus.
I contacted Joy by email, described the situation.
He offered to send him for diagnosis.
Sent to China. A month later the parcel reached.
For a very long time there was a diagnosis.
Then Joy wrote that everything is all right and sends the camera back.
All this took three months.
Got a completely new camera.
Support Super. Great Respect.
Mini 0807 - MOD-4
Changelog 17.11.2017
-Bitrate 32-28-24Mbits
-Gamma 16...235
-Saturation
-AUTO Reduce Sharpness (low light)
-Backlight Compensation
-Table of Expo
-Scene #1
-DE #1
-AutoISO in video mode
The main changes concern the ISO parameters, sharpness and noise reduction
in automatic mode, when lighting changes in a frame.
Optimum exposure compensation values -0.7 ...- 1.0
N.B. The main change is the reduction of excessive sharpness.
Please upload short video originals or full-sized screenshots.
At the moment I do not have free time to test the firmware...
Hello to all. I'm undecided between the Mini 0807 and the Mini 0806s (I should connect it to the car radio and so while with the 0806s I would directly output the RCA video output with 0807 I should put an HDMI to RCA converter).
But on 0807 I read that it has much more advanced parking modes including pre-buffer mode ...
I would have some questions:
1) Is the pre-buffer parking mode working or problematic?
2) the dual micro SD as it works? That is, as soon as the micro SD fills up automatically starts writing on B and then goes back to writing on A? And this feature really works or is it a problem?
Thanks for the moment
Anyone having issues with their micro sd cards? I'm currently using 64gb samsung evo cards and when the card gets full it can't overwrite the old files and crashes the dashcam. The Samsung pro cards work fine.
Fully format the card; that'll sort it. If you can't do in the camera, then use a PC.
I have tried everyone possible. Formating on both dashcam and pc, turning motion off, factory reset, firmware reset. None of these fix the problem.
Then you have a faulty card. Dump it and carry on using the Samsung card.
It's not faulty. There are no bad sectors on it and they work perfectly fine in my phone and cameras.
