Mini 0807
Hi All))
Lens holder on my mini 0807 was a bit broken, when i try to fix focus. There was a small crack
Where i can buy a new one?
Can i use gopro lens and holder?
Can you help me with dimentions of lens holder?
Thank a lot for help)))
I loaded the new 20160623 V1.0 firmware.
Overall VBR is around 14.9 - 15.8 mbps.
Video VBR is 14.6 - 14.9 mbps and audio is 128 kbps.
A 3 minute file is 327 - 348 mb in size.
Code:
General
Complete name                            : E:\DCIM\100MEDIA\06241153_0005.MOV
Format                                   : MPEG-4
Format profile                           : QuickTime
Codec ID                                 : qt   0000.00 (qt  )
File size                                : 340 MiB
Duration                                 : 3mn 0s
Overall bit rate mode                    : Variable
Overall bit rate                         : 15.8 Mbps
Encoded date                             : UTC 2016-06-24 11:53:19
Tagged date                              : UTC 2016-06-24 11:53:19
AMBA                                     :
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=3, N=15
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 3mn 0s
Bit rate mode                            : Variable
Bit rate                                 : 14.9 Mbps
Maximum bit rate                         : 18.0 Mbps
Width                                    : 1 920 pixels
Clean aperture width                     : 1 920 pixels
Height                                   : 1 080 pixels
Clean aperture height                    : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 29.970 (30000/1001) fps
Color space                              : YUV
Will test on the road soon.
Hi All))
Hi Adreim, let me help you.
Thanks for helping, Bella))) I send PM to you.
Hi All,
I have a new 0807, and want to know if someone can talk me through the ADAS calibration?
Also, I found that the screen display (the screensaver on the camera when I drive) is a bit too fast. My speedometer shows about 2-3 mph slower than the display, but when I look at the video file the speed stamp information is slower than my speedometer in the car. So, to clarify, an example would be:
  • 0807 display during recording = 33mph
  • Speedometer in car = 30mph
  • downloaded video file speed stamp = 28mph
Anyone else seen this?
I'am a little bit confused because I found sellers of the mini 807 with brand names like Toguard and Adashine, are these genuine and if not how can I found out that I purchase an original one?
Hi , These are our retailer, you can buy
Hi All,
Hi , we will check and come back later.thanks
They are our retailer , you can buy from them ,thank for caring our Mini0807 .
@gyrex,
Please send mail to me joy@skyhigh-global.com about your firmware version then I will send to you , because there are firmware with different hardware and some users make mistake to brick the camera, so we delete the firmware from our website.
@gyrex,
Hi. After updating firmware, dashcam bricks. Please help me.
Hi Joy,
Is it not possible to list on your website for which firmware the new firmware version is valid (list all the previous versions too) and put the download link back, because I"ll think your Inbox will be flooded with firmware request.
Hi Joy,
even you write which version people still install the wrong one because they think they can, then it becomes RMA problem for the seller, that's bigger problem than how many emails in your inbox
