So, today was full day when testing again v1.01.09 with two different cards.
Settings:
BDP: 6h cut-off, ( 12.4, 12.1 V )
First half day tested with two 32Gb Lexar 32Gb 633x.
With 12.4V was able to record only 5-6 sec after going from driving to Parking mode, but no lock up or freeze when starting an engine or going from drive to park. My car battery is quite old and probably 12.4V BDP is no good for me, so 5.-6 sec recording in parking mode was expected.
After changed from 12.4v to 12.1 ( 6h ). Was checking up on my parked car every 1 hour and parking recording was working nicely. Every hour started engine for 1 min just to check park to drive to park switching. No freezes, no lock-up, all fine.
Second half of the day I tested with Transcend 64Gb 300x. BDP 12.1 ( 6h ). Same story as earlier: checked every hour status of the unit and all was working fine. Also turning engine on for 1 min, then off to check switching between drive and parking mode.
Parked my car 6.05pm and was checking the status of the unit every now and then, - X2 was nicely working in parking mode. 10 minutes ago I was able to see that X2 is turned-off, what means that 6 hour BDP kicked-in.
I am using previous type of GPS antenna with blue LED, which blinks when X2 is turned ON ( recording, or just in parking mode stand-by, but it shows that unit is active ). I prefer this type of GPS antenna with blue LED to the new ones, because then I can see if X2 works or not, dont need to go all the time inside car to check. Very convenient and it gives additional "fake security system effect". I wish this GPS antenna would be back in production.
The only "issue" with v.1.01.09 is that "beep" of touchscreen can not be turned off. Other than that it was and is working fine, except in parking mode G-sensor still not activating a rear camera recording ( motion detection works fine for front and rear ),- this seems to be a common issue with most firmwares.
P.S ! - those are only first day of tests. It's too early to glorify, but first signs are good. However I would let another 3-4 days of constant testings and monitoring to make more correct conclusions where using a different capacity and brand memory cards.
I also encourage others to roll back to v1.01.09 and see how it works for them.
