winter4w
- Jun 12, 2014
- G1WH
winter4w, I have attached the specs for the Cellink Neo. Where I am we have great variability in temps from high 90's F in the summer to -20+F in winter (based upon feedback from others on this site, the bigger risk seems to be with charging when the Neo is below freezing). I mounted mine under the front seat using the included Velcro strips. I determined this to be the coolest location (i.e. low on the floor, gets hit with AC air during driving and not in direct sunlight). I ordered the Neo with the 3-wire unspliced option (BAT, ACC and GND) which is an exact match for the 3 wires in the SGDCHW kit. If you were to go this route, I would likely use a fuse tap to to the #4 fuse (Front Fog Lamps) as it is a 15 amp circuit and it should only be hot with the ignition on (the Neo only has two wires for attaching to your car, one for GND and the other ACC). Since the Neo only draws a max of 9 amps, as long as you rarely use the fogs it would be the ideal circuit, IMO. In the Cellink app pic 25C is 77F, my car sits in a garage attached to my house so that is the approximate ambient temp in my car. I'm very pleased with the Neo, with the 2 camera SG9663DC set-up it should provide output for approx 25+ hours. I will take a screen grab while the car is running and also when I turn it off so that you can see the app info during the charge and discharge states.
On another cautionary point I would be hesitant to use the cigarette lighter (#11) for any device as it is also the circuit for the air bag system, not sure how that got certified!!!
How did you hook it up to the SG9663DC? Would I need to cut the ends off and clamp them to the Neo? And yea I use fuse 10 right now for ACC since it does not interfere with the SRS airbags. Also would the hardwire kit power off the camera when the Neo gets low?
