Are you still planing to release the hide-away model? For me that is the key feature.
Will it be able to warn you if it's not able to write to a card?
Ooh, and will it take full size SD cards instead of input microSD?
MicroSD fits into many smartphone/tablets these days too. 256GB microSD works great in my SG9665GC
When really is the realistic target release date?
Dang. I was hoping that since a remote unit form factor could be more flexible, full size SD cards which are cheaper in larger capacities with more varied offerings might be an option.
Ok, thanks. Something to keep in mind. I'm not sure what other devices (phones?) have to do with it. And I realize they're making microSD cards in 256GB now, but they're more expensive than the cameras themselves. Full size SD cards offer more variety (including larger MLC offerings) for less money. That's a good thing. Whether it makes sense for a given product or not, I have no idea, just passing it along.
The smartphone/tablet/dash cam interchangeability is a good point.
i had a camera mounted in front of the sliding rear window on my tacoma (2005 x-runner). the trick is to attach something to the metal inside the headliner above the back window, so that it hangs down in front of the glass, then attach the camera to that. failing that, attach it to the headliner.
skip ahead to 30 seconds and you can see the view it gives. (note, not a SG cam, but you get the idea)
edit: install photos here:
https://dashcamtalk.com/forum/threads/ch-100b-video-review.15063/#post-237707
In regard to the small memory cards, i am okay with them as long as the design around the slot they go into have been made with care.
If you still need untrimmed fingernails to best insert and remove them, then i am still against the small memory cards, but if its designed and made with attention to this matter then there will be no problems at all.
