kamkar
- Oct 11, 2013
- Denmark
- 10 years, many dashcams
Okay i got the camera installed today, or that is the front main body and the 2 cameras in it.
And i have run into problems already.
Last night running static testing on the table, the camera stopped recording, then do 4-5 beeps, and then give the startup announcement and keep recording.
The camera did the same today on my drive home, so the A139 is at hand as reference / evidence camera.
As this is happening you can also see some " digital noise / blocking going on in the bottom part of the front camera feed, this is not present in the cabin camera, even if i am using the middle 50 % of the 2 cameras here you can see the issue in the T130 feed right at the start in the video.
I have so far only looked thru a few of the other filed from before the camera reboot, but i have not seen any of that digital noise in any of those files, so it is probably pertaining to the reboot, it is before the event and the T130 reboot, after the reboot the T130 footage are fine again.
There is no card error MSG or anything the T130 just seem to reboot beep 4 -5 times as you can hear / see in the screen shot from my edit software, and then start to record and of course announce 2 channels are recording.
When it happned last night it was after several hours of recording ( 3 at least ) when it happned today i had only been driving for 40 - 45 min and with 3-4 hours pause at our dinner.
The memory card used on this drive and static testing last night was a Sandisk high endurance 128 GB.
