runtohell121
- Jul 10, 2013
- United States
- Viofo & Vantrue - too many to list
I thought I noticed the dashcam switching which cameras are recording all by itself, too, but I wasn’t sure, so I haven’t posted anything about this yet. I wanted to be more methodical abut my testing first. I didn’t connect the change in which cameras are recording to the file dropout…. This would seem to indicate something might be causing the dashcam to reset itself somehow.Strangest thing is... this morning I set to record front + rear only... almost to work at ~8:19am, it stopped recording and switched back to 3 channel (front + interior + rear).
1 minute loops.
This is a tuff one. You probably only noticed it because you were dutifully scanning your SD card files. On Viofo dashcams, there is an alert "Recording, 'X' Channel started" when the camera glitches during an interrupted loop. There is still a gap in the recording, but at least you know there is a problem. I just had this happen on my A229 Pro last week, there was a random 2 second long recording and then I got the message alert before the next full 3 minute loop started.@jsmith
Here's a screenshot from 5:21pm -> 5:22pm from the front camera.
5:21pm clip ended early at only 14 seconds - timestamp 17:21:25
Next clip 5:22pm file - timestamp 17:21:41 - missed 16 seconds of recording
Are you recording on all three channels?So I've run the Vantrue N4S for 3 days now on a 128GB Vantrue SD card with 3 Minute Loop Recording. I am not finding irregular file sizes or gaps after 3 days. I'll continue the test longer and see what happens.
I wonder if this is a heat related issue or a memory card problem?
I've had my N4S set to 3min loops from the start. Still seeing drop outs. New rear camera is on the way, so I'm hoping that resolves the issue.
As far as I know, the latest Firmware for N4S is N4S_VT-EED181Are you running the NEWEST FIRMWARE on the old camera?
After switching from the Sandisk --> Vantrue MicroSD what I thought was the same issue as here turned out to be different. I've monitored the simcard for 5 days. Now that car is maybe used for a few hours a day tops right now, but I cannot recreate the issue of missing footage now.
Vantrue told me on July 8 that they have not uploaded any N4S Firmware yet to their website.
@jsmith
Asked me to switch to 3 minute - same issues. Short drives during work week.
Scary thing if one was thinking the N4S was recording, it was not recording for ~20 min of the drive during the drive home from 5:40PM to 6:05PM
I’ve used two different Vantrue SD cards, so I’m thinking that’s not the issue.
