rcg530
- Jan 23, 2021
- California
- 70mai, BlackVue, Thinkware, Vantrue, Vueroid, VIOFO
While I'm waiting for firmware updates for the A229 Pro / A229 Plus dash cameras from VIOFO, I removed the Vantrue S1 Pro dash camera and the VIOFO A229 Pro front camera from my car's windshield to make room so I can install two A119 Mini 2 dash cameras side-by-side. Unfortunately, one of the two A119 Mini 2 dash cameras with the updated lens has a memory card slot problem. It will randomly detect or not detect a memory card being present in the memory card slot. I've asked VIOFO for a replacement for that dash camera. The problem showed up right when I checked the unit after receiving it and then it stopped for a short period of time and now the problem is back. I have a memory card in that second A119 Mini 2 that is "working" for the moment.
I want to gather footage using both units (CPL vs no CPL, HDR on vs HDR off, etc). I'm also experimenting with an idea I tried last year in trying to reduce the amount of direct sunlight that reaches the A119 Mini / A119 Mini 2. Last year's test was using a window screen film with small holes in it. That did help a bit. My new test is using a 3-D printed sunshade. This is just an experiment and a way to learn how to use 3-D modeling software and testing out my AnkerMake M5 3-D printer.
This is my A119 Mini / Mini 2 sunshade (top side view). There's a mounting block that is used to attach the entire thing to the windshield. It's 4mm thick which allows the main body to be offset from the windshield glass. There are air vents in the main body (90 degree vents - to not allow direct sunlight through) and then some "wings" on the side to block sunlight from directly hitting the side of the A119 Mini / Mini 2 case. There's notch on the bottom edge to allow the lens with a CPL filter to be rotated to its most upright position and not hit the sunshade. I use 3M 5952 VHB tape to adhere the sunshade to the windshield. The sunshade is 3-D printed using 1.75mm PLA+ filament on my AnkerMake M5 3-D printer.
This is the A119 Mini / A119 Mini 2 side of the sunshade. The center portion is where the adhesive tape on the GPS module attaches to the sunshade. You can see the bottom side of the 90 degree air vents as well.
Here's what it looks like installed in my car. Before you ask, I've made sure the HK4 connector that looks a bit off in the picture is fully pressed into the GPS module (after taking the pictures).
Last Friday, I confirmed the GPS module reception is not impacted by the presence of the sunshade and the 3M 5952 VHB tape worked well in keeping the dash camera and the sunshade attached to the windshield.
The weather forecast for this week shows temps returning to the upper 80s F to low 90s F. I hope to have some thermal pictures showing how much if any temperature difference there is between the two A119 Mini 2 dash cameras.
