Hardcore
If you have it plugged into the accessory socket, then probably the socket turns off while cranking the engine.
The best solution is to hardwire the camera into the ignition power so that it doesn't turn off while cranking.
Ignition pos 2, not 1
I'm using the HK3 hard wire kit.
The kit is hard wired into the ignition live for position 2 in the internal fuse box and a permanent live.
If the car is driven frequently through the day it boots 100% of the time
But if it's been sitting overnight or similar, about 50% of the time it fails to boot as it cuts off as soon as i begin turn the engine over. Even though the engine starts in about 1 second, it's that initial turn over that causes the REC light to go off, then it needs to be powered up manually.
