V1.02Anyone have a backup or link to download firmware v1.02?
° Can I connect dash cam with AV OUT cable with android smartphone?
Yes you can - you'd need a USB On-The-Go (OTG) compatible phone, an OTG cable from whatever your phone has to USB-A and then an EasyCap based USB capture card (some of the cheap clones would work with Android too but it's a gamble sometimes which you receive).° Can I connect dash cam with AV OUT cable with android smartphone?
True, they forgot to add that the WDR smears the picture, even in good light.HDR (translates as “high dynamic range”) is a special technology that enhances the graininess and contrast of videos. Its use allows you to make the picture more saturated and bright, increasing sharpness.
This is a function that will improve the picture obtained in adverse environmental conditions. In particular, it eliminates the negative impact of bright sunlight, preventing the image from being exposed to light. The quality of videos shot in the dark is also greatly improved.
HDR setup is done via the menu, function keys and display. Just select the item responsible for adjusting the image.
In the case of WDR, the DVR is equipped with an improved matrix, it is worth noting that WDR is a more expensive option, since it is based on making changes at the hardware level, providing for the installation of a special matrix.
But this technology is more functional and makes it possible to get a better and more realistic picture, even with a sharp difference in illumination.
Interesting...On amazon.de I read an interesting review about the VIOFO TK3 module. The module was installed with an A129, but the same goes for the A119 V3. Beside positive points there is also a negative one. The VIOFO TK3 module switches off at lower voltages than set! If you e.g. set 12.2 Volt, it only switches off at under 11.8 Volt! It was always 0.4 Volt lower than set.
VIOFO can solve this circumstance easily by adjusting the resistors R19 and R20. More details below in the text.
Customer Review:
The module is quite small and has nice long cables, which should be sufficient for most vehicles.
I found the operation quite self-explanatory:
* on the module is a slide switch, with which you can adjust with four positions, from which lower voltage threshold it switches off. So the car battery should not be discharged too much. Very practical if you leave the car standing longer.
* The module does not switch off immediately if the voltage falls below the lower voltage threshold, but only after approx. 30 seconds. This prevents the camera from suddenly shutting down if the battery voltage only drops for a short time. (e.g. if you open all windows at the same time or start the engine)
* On the camera you then set that you want to have the park mode and the camera already records a time lapse video (without sound) when you turn off the ignition.
I installed the module myself in the fuse box of the car, fused by my own 1A fuse. I could then lay the cables invisibly under the interior cover. At least with my car this worked well (Citroen C3).
Now we come to the disadvantages:
- At least my module switched off at much lower voltages than set! If I set e.g. 12.2 Volt, it only switched off at below 11.8 Volt! It was always 0.4 Volt lower than set. I wanted to set the threshold to 12.2 Volt, but I couldn't do that! At the highest setting of 12.4 Volt the module switched off at below 12 Volt.
- The camera used, Viofo A129 Duo, consumes a current of 200 mA in park mode (front and rear camera connected). Interestingly, this is only 10mA less than in normal driving mode. I think it's quite a lot.
For technology affinity:
I could eliminate the fact that the actual switching thresholds were 400mV lower than set. I exchanged two voltage divider resistors R19 & R20:
Old value: R19 = 75kΩ R20 = 10KΩ
New value: R19 = 100kΩ R20 = 13kΩ
There were SMD resistors in the 0603 package. You can get them in electronics shops or even here on Amazon.
The module is easy to disassemble, the corresponding screws are under the label.
Gentlemen, revive the topic !!!
Here is the MOD firmware
Default:
1440P
Bitrate 50
HDR on
Next, configure yourself.
1.03Is it based on 1.02 or 1.03?
Default:
1440P
Bitrate 50
HDR on
MOD_50 FWA119V3.zip
drive.google.com
The work of this firmware is the from above video !!
I do not understand what to lower / change?Can you downgrade/change firmware back to stock V1.03 after updating to modded firmware?
Yes.Can you downgrade/change firmware back to stock V1.03 after updating to modded firmware?
And the error of the expo parameter?HDR can be supported in the near future
D | Viofo A119 V3 Issue | A119 V3 | 11 | |
R | Viofo A119 V3 HDR/Not HDR, 60fps/30fps, CPL/No CPL | A119 V3 | 21 | |
R | Viofo A119 V3 on special price | A119 V3 | 1 | |
D | Viofo A119 v3 (Firmware 2.6) Stop & Go on Red Lights | A119 V3 | 5 | |
VIOFO A119 V3 no longer recording GPS | A119 V3 | 7 |
