valkyrie
What can we test if our cameras are working OK in parking mode?
After I saw your report here I made a parking mode test and was working OK for me from the first time.
As an old beta tester I tried to analyze what is different between our setups and I see you are using Powe Bank. I was using wall charger with original cable, so the test was indoor like yours and should not be affected by the GPS firmware changes.
IDK if yours is working ok.
I know Capture Your Action hasn't had consistent results either at times.
A119 V3 Does not sense or enter Parking mode after firmware update V1.03
Just as the title says, after updating firmware to V1.03, the A119 V3 does not enter Parking modes with only DC. Does not enter Parking mode with Hardwire kit unless ignition switch is first turned on and off.
www.viofo.com
On the Viofo forum he posted this the other day.
"I'm running more parking mode tests now. First test using a 5V USB power supply, the camera did not enter parking mode after 27 minutes. I changed a few settings and am testing again. "
So I know it's not just mine.
