Velvetfoot
I'm thinking the 90 seconds could allow for the vagaries of accessory power behavior on different cars.
Doesn’t work as well during the day, but seems fairly good at night.I tried to snag a license plate from today's drive with HDR on.
I believe I see the multi-imaging that was referred to earlier in the thread.
So, would you say it's an improvement over having it turned off during the day?Doesn’t work as well during the day, but seems fairly good at night.
Ideally it would be off during the day and on at night. There is a possibility (I stress possibility) that Viofo could add some kind of setting that would automatically turn it on and off based on the time. There is a thread on DashCamTalk showing still shots of plate numbers at night (with HDR on).So, would you say it's an improvement over having it turned off during the day?
I just read that thread (and registered, lol).HDR on the beta version.
True HDR will be supported on V3.
True HDR will be supported on V3 for 2K 30fps video recording.www.viofo.com
Not sure. Possible that the camera defaulted to 30fps when you enabled HDR. You'd have to check your video to see.I just read that thread (and registered, lol).
Does HDR still only work at 30fps, because I was at 60fps.
Properties show 60fps.Not sure. Possible that the camera defaulted to 30fps when you enabled HDR. You'd have to check your video to see.
I couldn't duplicate that. I actually tried auto event detection for the first time, and it worked. I walked in front, and the REC light went solid and recorded.Well that sucked. I upgraded the firmware (yes, I did the factory reset and hard reset) but no matter what settings I tried the parking mode wouldn't trigger and record anything, it just stayed with the rapidly blinking record LED, I tried jumping up and down in front of the camera, flashing the lights and nothing was recorded. I've gone back to using the previous firmware until I read that things have been fixed (I've retested the rollback firmware and everything is working as it should)
D | Viofo A119 V3 Issue | A119 V3 | 11 | |
R | Viofo A119 V3 HDR/Not HDR, 60fps/30fps, CPL/No CPL | A119 V3 | 21 | |
R | Viofo A119 V3 on special price | A119 V3 | 1 | |
D | Viofo A119 v3 (Firmware 2.6) Stop & Go on Red Lights | A119 V3 | 5 | |
VIOFO A119 V3 no longer recording GPS | A119 V3 | 7 |
