ljw2k
- Feb 2, 2016
- United Kingdom
The photo of Hoya CPL is deceiving, all digital camera camcorders require adjustable CPLs meaning the out ring actually turns 360degrees to allow variety of light control. You are seeing two rings but its just the outer lens attached to its own rotating base not an adapter. All camera CPLs are thicker for this reason.
^This.
The lens is much heavier than the original plastic one but I don't think it is a problem as it takes a little force to move the lens up & down and once you have the lens where you want it you could always use a little Hot Glue or a lump of blue tack but I really don't think its a problem. The trouble is if you go smaller then you have the chance of the vignetting again as the A119s has a wide angle lens.
