Viofo A129
Installed my viofo this way.... Very discreet and no vibration.
What car is it? Because the cover of my focus is weak and vibrate. I tried put a129 there, but not's good result.
Enviado do meu FRD-L19 através do Tapatalk
Wouldn't it have a lot of glare/reflection from the windshield, because of the distance from the glass? Are you using the optional filter?
Our lane detection camera 'hump' looks almost identical on the Honda CRV, but I mounted it just to the right. I like how discrete yours is, though!
The Viofo A119 needs 4 pins cable with GND in the position from the picture:
the other pins are not important.
enjoy,
Mtz
have a similar cable and it does not work 🙁
I found a photo with two types of mini jack:
Which type is correct for A129?
I believe the type A is what you need
  • Like
Reactions: Mtz
What is displayed on the A129 AV out? Is it front/rear/PIP toggle identical to the main unit screen?
I am using a Samsung MicroSDXC EVO Plus Class 10 UHS-I. It works perfectly on my A129 Duo. Can't tell much you about reliability though, as I bought it less than a month ago, but having used Samsung SD cards before, I trust them.
Guys, what player do you use on pc for whatch A129 videos with gps ? Is there some free?
I use Dashcam Viewer but it's $25. There is also the Registrator Viewer software which I heard it's free, but you need to find the virus free version. Somebody here posted a link to a clean one.
Free Viewers which supports GPS data and works with all VIOFO Cams
NEXTBASE-Replay-3-Setup-3.10.0.exe <========= 90MB Windows 7-10
https://www.nextbase.com/en-gb/help-and-support/
RegistratorViewer6001.exe <========= 1.1MB Windows 7-10 (must extract GPS data from MP4 manually then save to folder with video clip)
https://drive.google.com/open?id=1LI8jQtb0Jv4zrx6X22gPn_Ae2RmSMM9V
The nextbase Replay 3 works for me, but I have a problem with show the gps map (google maps), the message appears: this page not uploaded google maps correctly. See the Javascript console to see technical details.
Latest A129 firmware is released , version number is V1.5
Change log:
  1. Added: New parking mode solution, support VIOFO 2 wires and 3 wires ACC hardwire kit.
  2. Added: 2fps, 3fps options for time lapse parking mode
  3. Added: Support show SSID, Car License number, Customize Text on APP.
  4. Added: Support rear camera mirror
  5. Added: Time zone option: -2:30
  6. Updated: Support take a video snapshot while lock the video by remote control
  7. Updated: Wake up the screen first while press the Menu / Rec / Mic / Video Source switch button in screen save mode;
  8. Updated: Date format YY/MM/DD changed to YY – MM – DD
  9. Updated: Enter parking mode duration 90s changed to 5mins while use 2 wires hardwire cable
https://support.viofo.com/support/solutions/articles/19000087812-viofo-a129-duo-dash-cam-firmware
Good to see V1.5 as a full release to support the hardwire kits and parking modes. I know some people may not like installing beta firmware.
So whats the diff btw the v 1.5 beta and the official 1.5 release, if any? Do we have to install it again?
If the version number hasn’t changed generally the public release is just the approved version of the same beta.
