I guess the plastic it is mounted to is vibrating a bit at that speed.
I would be interested to see some video from the highway, probably it is fine, but it would be interesting to see...
Do you have Lidar (for automatic collision avoidance?)
Just wondering if that could be causing some interference when it fires the laser...
If you could test the A229 away from the car camera, maybe plug it into a USB powerbank with it off the mount, then move it closer and further away, then we can know if the car camera is the cause if it gets worse as it gets closer...
I've not seen anyone else reporting this, apart from the above mention of 5GHz.
Thanks for posting the images.
It is feasible, but most people testing are using 5GHz, because 2.4GHz is not always fast enough to avoid buffering on the live stream, and most other people have not seen this problem.
