Vueroid S1-4K Infinite - Test & Review PP
@meyelow_Vue
I knew I should have posted the raw / original files in a Google drive for you to employ your "magic".
But I recently lost my high speed internet, so it takes forever to upload video files to my Google drive, and YouTube.
I'm also curious about the horizon line adjustment. If I align the dashcam in our Toyota RAV4 to 50% road and 50% sky, the video captures some of the dashboard. I'm not sure if that's okay. My concern is that if there is too much sky in the frame, the road will become a bit underexposed.
If you want your S1-4K to function properly and have good video quality and legible license plates,
I recommend following the manufacturer's recommendations.
Each manufacturer has its own recommendations, and they may differ from those of other manufacturers.
Random Test Footage (Firmware v1.4.2)
At the request of you know who, I gathered DAYTIME test footage with Vueroid’s new Horizon Line Adjustment recommendation offered in VueroidHUB APP.
The new recommendation is approximately 40% Road / 60% Sky.
For comparison I’ve got Viofo A329S Front, (50% Road & 50% Sky), and the Viofo Telephoto.
Check out the GPS Coordinates & Time on both screenshots.
Jack Trotter III Esq. would say; IDENTICAL!
CAMERA SETTINGS:
S1-4K
Firmware: v.1.4.2
Resolution: 4K30fps
HDR + IPC: Who knows? I can’t be trusted 😔
Bitrate: HIGH (highest setting)
1 Minute File Size: 394MB
CPL Filter: Yes
SD Card: 512GB Vueroid
Power Source: Vueroid 12V Hardwire Cable
A329S
Firmware: V2.0_260104
Resolution: 4K30fps Front
Resolution: 2K30fps Telephoto
HDR: OFF
Bitrate: MAXIMUM (highest setting)
1 Minute File Size: 384MB Front
1 Minute File Size: 172MB Telephoto
CPL Filter: Yes (front & telephoto)
SD Card: 512GB Viofo
Power Source: Viofo HK6 Hardwire Cable
I find it difficult to understand the comparison of footage between HDR+IPC Mode and Normal (Linear) Mode in daytime conditions. I also still believe that Normal Mode is the recommended setting during the day. That is why we recently implemented the Timed IPC mode.
Under sufficient daylight conditions, the strengths of Normal (Linear) Mode cannot be matched by any HDR. Of course, backlighting or reflections that may occasionally occur can be a drawback.
Furthermore, I am curious about the purpose of including a telephoto camera in the comparison. Once the Vueroid telephoto camera is released, I would appreciate it if you could make the comparison at that time.
I love how everyone is overthinking the horizon line on dash cam talk.
all because one member a long time ago said it needs to be 50/50 with no scientific evidence of why.
Really the line should be used as a reference and when installed you should also look at reflections from your dash and make adjustments accordingly.
Now this whole at HDR on and HDR off thing is getting quite cumbersome. Customers are not going to be adjusting everyday and changing timers. This is inadequate from all dash camera manufacturers. The only people it benefits are the tech people on dashcamtalk.
Dash camera manufacturers need to have a better solution 1 setting to rule them all. these extensive settings is what gives the red tigers of the world power. The reason why is because barely any settings and its not overly complicated. My opinion of red tiger is unchanged in terms of quality. However the extensive settings of some of these brands make it too complicated for average customers.
2027 lets have 1 video setting
@Chuck McCoy said:
Way back when we had the WeChat group chat I asked CTO Kim what setting I should use for all public test footage.
He said to use HDR + IPC at all times (day & night) so that's what I did.
The good news is I have decided to use HDR ON on all VIOFO dash cams from now on, (day & night).
I made a post about it HERE #7
@Chuck McCoy I included the Telephoto footage just because it was available and it felt like a waste to not include it.
I hope you guys did not make the same mistake with the rear camera, (I hope the Telephoto has optional CPL Filter, and HDR performance that is equal to the front camera).
Also, if customers buy the Telephoto they will want a rear camera instead of the IR interior camera, so I hope you offer an optional 1080p "rear" camera.
This is also why I said it's important to have "remote camera modularity" any remote camera works with any output.
I'm rooting for you, FIGHTING!
-Chuck
@Chuck McCoy said:
I was told to use 50/50 when comparing two different dash cams so it makes for an equal comparison by @Mtz and @Nigel
This was the explanation.
When I first tested the prototype Telephoto for A229 Pro, VIOFO told me to use more road than sky.
I thought that meant 60% road 40% sky.
But I later found out 70% road 30% sky works best on the Telephoto.
@Chuck McCoy said:
YES! YES! YES! YES! YES!
-Chuck
you'd better to use timed IPC , cuase the linear is the best image quality at daytime . I can't exactly rember when I recommended HDR+IPC S1 support timed IPC or not . ( Maybe at that time S1 was not ready for time IPC)
....to add insult to injury, there were those here who swore by it, preached it, and ignored others who said otherwise. Recently, I am sure I annoyed other Vueroid testers and employees with my insistence that the recommended setting for the 'horizon' line was too high, as it was causing lens glare on the video. But as you and I discussed, there may be a language barrier in the use of "horizon" and "horizontal line".
Regardless, I set my lens to capture more of the earth and less of the sky. I have no interest in the sky above the traffic signal, only in what is below it.
This has been resolved by Vueroid on upcoming releases, in my opinion. I am afraid that a part of the issue is that many in the user base have become more educated about features and are more demanding. It is upon the manufacturer to implement these features in a sane way. What we often have is a clash in the two cultures as to what are the important features and how to implement those features into the GUI. Sometimes I explain it clearly, sometimes I don't. Sometimes, minds are already made up.
I have no idea whether that was recommended. If so, that is old news, applied to the firmware release at that time, and is not applicable today. So, it is not even worth mentioning old settings or recommendations, as this adds confusion to the user base.
@qusejr2 said:
you'd better to use timed IPC, because the linear is the best image quality at daytime.
@Chuck McCoy said:
Like Ben said, I’m getting fed up with all the settings, and timers.
The average consumer will perform initial settings during installation, and most likely never touch the dash cam again until they need to download a video after an incident.
Settings need to be “set it & forget it”.
Moving forward I will only be using one setting for gathering all test footage for comparison.
Obviously HDR + IPC on, (day & night) is going to be the best compromise.
Not interested in any timers.
Maybe one day HDR tuning will be so good it can be left on all the time.
-Chuck
Perhaps one day this will happen, but at the moment you can’t do without a timer if you want to see legible license plates of oncoming cars on video, day and night.
It's worth remembering that the timer was added at user request.
Those who don't care about the timer don't have to use it.
Just don't ask manufacturers to remove it from the settings.
Precisely that. Users here and on other social media wanted better images, license plate capture, beautiful skys...they wanted the cinematic experience from a 4K dashcam. Then they complain because they can't master the settings the manufacturer provided to improve the image. If testers are not prepared to use those settings and provide valid information to users, they should stick with 37-dollar Alibaba dashcams. This is the same with a CPL. Owners use one, or they do not. If they use a CPL, then they need to know the image will appear differently on the video, and they may need to adjust settings for day and night driving.
High-end dashcams are not a point-and-shoot camera. Owners have to learn to use them; if they are not willing to do this, they should stick with a dash cam with fewer features, but that still provides a video image to provide a witness video.
I agree with this opion. and we will keep on studying how to solve it ( for example , get a sunset / sunrise DB all region and set it automatically .. in the future)
I think it's too~~ way back. We changed IPC's concept recently. Not only IPC but also other parameters and features could be changed if it is more reasonable.
-Chuck
Thank you so much~~!
Wow~~ I completely agree with this statement. As soon as I read it, it reminded me of the time when I was deeply into DSLR cameras.
There are many different types of digital cameras as well. DSLR is considered high-end, but even within that category, the price range varies tremendously. There were many different kinds of digital cameras such as mirrorless cameras, compact cameras, and so on.
To properly use a DSLR, you have to study and learn quite a lot. In return, however, it delivers a feeling and image quality that compact cameras simply cannot reproduce.
Of course, I’ve also seen many people just leave their DSLR in auto mode and use it that way. Even then, it still often produces results worthy of its cost.
That thought suddenly came to mind, so I decided to write it down.
This is my admirable CTO, who really seems to have no limits. It's just all about the inspiration. Inspire him, the feature will be implemented ~~~!!! 😉
Dashcams do not have an Auto mode and a Manual mode. Maybe they should??
To allow for dashcam users who are not interested in changing settings, I think it is important that the Default settings work reasonably well for most people.
A new dashcam, out of the box, should have the options set for at least daytime video. For the Vueroid S1-4K and later Vueroid models, the dashcams can be optimized and preset for daytime and nighttime video.
If a consumer buys a $100 dashcam, they know what they are getting. If a consumer buys a $500 dashcam, the expectation is that they should read the manual rather than treat it as mere packing material. At the same time, manufacturers can do a much better job at explaining features and how to use them. At present, manufacturers, due to the cost of paper manuals and inserts, seem to use a 'CliffsNotes' method for their manuals.
Of course, there is existing software and hardware tech that enable a dashcam to determine the current level of light and can be used to enable a nighttime setting; however, in the end, users would complain because the 'change' happened 30 minutes too late.
WRONG. Manufacturer who make higher end dash cameras should work better and have settings that are OPTIMIZED.
When you get a new phone it ask you questions.
1. Do you want big font?
2. Do you want dark mode or light mode?
It asks you questions for your preference.
Why does the dash camera not have a preference to how you drive.
The challenge is the manufacturer needs to correct how the image sensor does the heavy lifting. The reason you buy a more expensive point and shoot camera is because you want it to work better and take better pictures.
I understand the point of people should read and learn about their products.
Can you show me an owners guide for an IPHONE, or a Samsung Galaxy. They dont have one because well they work.
If you want to have a higher end product it should have a Beginner / Intermediate / Professional options menu
i actually piutched this idea to @viofo in March 2025. Because most users are overwhelmed by the sheer numbers of settings. Guess what the new app reflects nothing I gave for feedback except the wireless firmware updates. I will take that as a little win.
Something the manufacturers should think about. Stop pleasing super users and think about how the masses are using your product. There is no reason why in this day and age we can have 1 setting for an image sensor that auto detects lighting as your drive.
If there can not be I would love someone to explain that to me.
100%%% AGREE
