I have tried but I can't.The driver can be found at the folder which you already downloaded for the YicamUSB directed on one of your program files, "Xiaoyi"
I'm using a mac with parallels and I don't know if I use a PC it's better...
Ouuuhhh, yes! I had to install the driver manually...ups! Thanks! It works!! I´m going to release my xiaoyi after one month!! Thanks a lot!!!
Hi, I have done unbricking my camera with ELF Files after 3 red leds brick. After unbrick i stuck with another problem.
I've tried autoexe.ash files with yifirmware.bin, firmware.bin, reaname in autoexe.ash yifirmware.bin -> firmware.bin, but still nothing.
Can someone help me?
SOLVED
after this proses,have you update the firmware manually?Hi, i have a problem after unbrick
After update the firmware I have 3 red lightafter this proses,have you update the firmware manually?
,sory for my bad english 🙂
hi, may i know how did you install the driver? i found the files but i dont know what to do with it..I'm very happy. My Xiaomi is fixed and I can use it again!
Thanks for all my friends!
hi, i installed driver by this guidehi, may i know how did you install the driver? i found the files but i dont know what to do with it..
Thanks! I've successfully unbricked 3 red lights brick of my camera. But when I tried to update the firmware manually, it went to a beeping loop right away zzzz. Does anyone know the solution to this? It's stuck in a beeping loop. It beeps in an interval of 1s I guess? And the lights are blinkinghi, i installed driver by this guide
did you have trying to solve the unbrick with elf file?After update the firmware I have 3 red light
I unbrick my camera, but i have new problemdid you have trying to solve the unbrick with elf file?
try to hard reset,press power+wifi buttonI unbrick my camera, but i have new problem
What to do?
The camera has stopped working again
video
it's the same, mine is 23L and I did itMy Xiaomi Yi camera is bricked, but not the same bricking I am seeing here (it won't turn on at all - I only get red LED ring when it's charging, but no other signs of life. This happened after trying to do the focus fix and removing the front panel) AND it's a 23L, so the photo showing me what point on the camera to short to the chassis is not the same as the way my camera's front view (with panel removed) looks. Does anyone have a photo of the 23L showing what terminal to short to the chassis?
yes I have the same problem I want to change it back, please helpssas first many thanks @cruz. I managed to brick my cam after 1hr after I unpacked it 😀
While installing the new firmware it bricked. So I followed instrunctions from first post.
Used Z22 ELF file for my Z23A cam. After it I just let software install the newest update.
Cam seems to work fine.. but..
Camera Version is now: YDXJ_v22
Serial Number is wrong: starting with Z22 (instead of Z23A) and is not matching the number on the housing.
Is there a possiblity to change it back? At least the serial number...
