Totally sad after discovered that without the script 2.02 (I've removed the bitrate section from the script to avoid the 35mbit) and stock firmware the cam is not splitting my videos. I don't know what happens as it split in files of 300mb and the second file is bigger than it like 1.7gb... The problem is that part of the video is being lost, thank you tanckom by the previous support
having the same issue.
videos splitting and loosing videos as well. didnt modify anything, just used auto mode.
Any way to fix it?
also i would like to know the way to remove ximod? is it by deleting the files from sdcard?
Sorry to hear that... Yes, you just need to remove the files from the sd card.. let only the dcim folder and misc if I'm not wrong.. Or just copy your files and format the sdcard
Awesome!Working on 2.1.0. with updated scripts and with an Installer/Uninstaller.
Great job on https://xs-sol.com/ximode/
Hello,
1. Yes, no problem
2. Yes, if you really whish to start your camera without any modification, simply do all steps, which you do to load a script, and instead of pressing one, two, three,.... times, dont press it anytime. By pressing ZERO times, Ximode will load back into default mode. Want to switch back to modified mode? Use the normal way.
So:
0- defaulz
1-auto
2-normal
3-night
4-Yitune
5-SupYiView
6-Nightlapse
Thanks a lot!
The reason why I'm asking is that I'm using xiaomi on road bike in timelapse mode. The issue I have is that I don't like jpg quality so I made my own script to loop RAW only without jpg. All works fine, but to come back to normal usage (ex for video shooting or burst mode) I always had to delete autoexec first which was annoying
Now, with your script I can either add my custom RAW timelapse script or modify one of your existing scripts.
I only wish that the startup process would be easier in your solution... that would be briliant improvement!
Ex. start only with power button and add few seconds extra to have chance to enter the 'code' and if no code run with default settings. Would that be somehow possible?
Regards
Tomasz
A | Change from video to timelapse option via .ash file | Yi Action Camera | 0 | |
F | Some Videos Blank | Yi Action Camera | 0 | |
How to use Quik with Yi videos? | Yi Action Camera | 0 | ||
C | Video nightmare script | Yi Action Camera | 0 | |
Ximode - Normal (Script for daylight/everyday usage) | Yi Action Camera | 6 |
