We will release Zenfox hardwire cable in the near future.
When it is ready![]()
ACC means the accessories on a vehicle, like lights, car audio or air conditioner, etc. ACC hardwire cable can detect the ACC signal, when the car engine is off, the camera can switch to parking mode automatically, it is more exact than based on GPS.I think that "ACC" means "accessory" which implies that it's extra, not included.
Lots of Chinese websites and advertising pages seem to have poor translations to English, but it IS a very hard language to know and use well unless you grew up with it. And there are at least 3 major variations of it: UK, Australia, and US.
Always best to ask questions if you are not sure before buying, and to never presume that what you think is being said is what they actually intendGlad to see the cams are arriving and looking forward to the test results.
(EDIT to add: Just looked at the sales page for the first time and it seems translated well compared to many- I fully understood it easily.)
Please pause recording, press the MIC button for several seconds, there is an icon display on the screen.Here some info on the bitrates. The high and maximum bitrate has the same bitrates for interior and rear cams.
H.264 Low bit rate
Front cam: 2560x1440 30fps – Overall bit rate: 16.6 Mb/s. 119MB per 1min file.
Interior cam: 1920×1080 30fps – Overall bit rate: 8,462 kb/s. 60.6MB per 1min file.
Rear cam: 1920×1080 30fps – Overall bit rate: 8,473 kb/s. 60.6MB per 1min file.
H.264 Medium bit rate
Front cam: 2560x1440 30fps – Overall bit rate: 28.8 Mb/s. 206MB per 1min file.
Interior cam: 1920×1080 30fps – Overall bit rate: 12.5 Mb/s. 89.6MB per 1min file.
Rear cam: 1920×1080 30fps – Overall bit rate: 12.5 Mb/s. 89.7MB per 1min file.
H.264 High bitrate
Front cam: 2560x1440 30fps – Overall bit rate: 32.9 Mb/s. 235MB per 1min file.
Interior cam: 1920×1080 30fps – Overall bit rate: 16.6 Mb/s. 119MB per 1min file.
Rear cam: 1920×1080 30fps – Overall bit rate: 16.6 Mb/s. 119MB per 1min file.
H.264 Maximum bit rate
Front cam: 2560x1440 30fps – Overall bit rate: 46.1 Mb/s. 330MB per 1min file.
I can't seem to find the H.265 option. Maybe it's hidden like Viofo. Will try later when I'm in the car.
It is image mirror function.Does anyone know the function of this switch on the rear cam? I can't seem to find any info in the manual for it.
We are working on the hardwire kit, not sure the publishing time, the regular hardwire on the market is also suitable for T3.Not faulting Zen_Fox. Just hope a hardwire kit is sent out. Giving all us beta testers the best possible means to review each and every function the camera has to offer. I am very grateful Zen_Fox included me so please don't misconstrue my input as criticism Zen_Fox. I'm merely speaking from the perspective of wanting to offer you the most constructive innput humanly possible.
There is a mistake in our user manual, it is correct to press the right button to turn on Wi-Fi.In the current firmware, it is long press the right button!
The time is not sure now, you can use other brand hardwire cable.Any projections on release? Month? Two? or Not quite sure?
We are working on the hardwire kit, not sure the publishing time, the regular hardwire on the market is also suitable for T3.![]()
Will bitrates be the same when H265 is enabled (with maximum at 46-16-16)?Please pause recording, press the MIC button for several seconds, there is an icon display on the screen.
With the higher power draw of 3 cams, it would be wise to offer a HWK with ample capacity (like Viofo does with his cams) to reduce user problems. Many of the HWK's on offer today are not strong or have reliability problems in long term use.
Viofo HK3 is rated at 2 amps, T3 uses about 1.3 amps, maybe a bit more occasionally.I think you posted somewhere but cannot find. What is the power draw on the T3? And what is the Viofo hardwire kit rated for?
You have an HK3 cable on your windshield waiting to be tested...
Doesn't matter as long as it works!Well if I recall properly, there are two versions of the Viofo HK3 kit. One sent out with the A129 Duo, then a later update, which is what the A129 Pro uses. How can you tell which HK3 kit you're using?
Why do you have to make everything more complicated than it might actually be?
If you test it and encounter a problem, that is the time to look for explanations, and to report the problem.
If you create a virtual problem that prevents you even starting a test then we will make zero progress and be no more knowledgeable.
You don't know that the old kit was causing static, only that the combination of A129 + old HK3 caused an issue.because there were problems with the old kit causing static.
The T3 may be able to cope with all versions of HK3, although I suspect that when Zenfox said "you can use other brand hardwire cable.", that was a challenge for you to find problems and prove him/her wrong...
Remember that a successful test is one that finds a problem
If you don't find the problems then you have failed as a tester.
Zenfox T3 Stuck up logo... | Zenfox | 3 | |
Zenfox U1 2-Channel Dashcam Review | Zenfox | 12 | |
New Zenfox camera i just noticed | Zenfox | 7 | |
R | Zenfox T3 insides | Zenfox | 80 | |
J | Zenfox T3 3H review - Triple dashcam for ride sharing | Zenfox | 22 |
