Retired Guy
- Feb 10, 2015
Correct, if you plug it into the computer using the supplied cable then it will act as a disk drive, or two disk drives if you have both SD card slots filled and you wont be able to use the menus. Any other USB power source will probably charge it and allow you to use the menus or record at the same time.
If you don't know what a USB powerbank is then don't worry, it's just a battery with a USB socket!
Thanks again Nigel, I'm looking on Amazon right now and I see what a USB is, I'm going to get one, there are two that I'm looking at, one is 10,000 mAh and the other is 15,000 mAh, I think I'm gonna get the 15,000 mAh one. Thanks for the education.
