You can edit thread title from your PC.GC it is.
Just noticed the topic title is wrong too....
No it is't possible. My window is 62 degrees and the SG can only do 64. (Nowhere near the advertised "(near) vertical windows")If you're using the low cut it would probably do better aimed a bit higher than this if possible
But if I go up more, the influence of the sky will become bigger and the road will become even more dark wouldn't it?
And as you see I already have more than the recommended 40% sky.
camera look mounted at the bottom of the window, cant you move it up towards the top of window?I get the horizon at 495px from the top. so I think I even got the 64 and 62 the wrong way round.
that's a starting point, some situations will call for different adjustments
P | How to remove write protection to reformat SD card in SG9665GC? | SG9665GC | 7 | |
J | SG9665GCV3, power light comes on but no boot screen | SG9665GC | 4 | |
P | SG9665GC v1 and v2 Memory Cards | SG9665GC | 4 | |
A | Street Guardian SG9665GC V2 flashes power and mic light then turns off | SG9665GC | 5 | |
SG9665GC V2 Finally dead... | SG9665GC | 0 |
