Google Maps fix for RegistratorViewer (Windows)
Versions 6.0.0.22c and 6.0.0.22 (DeLorean)
AttachedThe video playback and everything else works perfectly
I'm using my own version which "only" removes the offending website link that was causing problems and compresses down the EXE... everything works perfectly including Google Maps etc.
https://www.dropbox.com/s/5cxksffp9dnlrvk/DATAKAM PLAYER - Registrator Viewer v.6.0.0.22 (DeLorean).zip?dl=0
Looking at your screen shots you've made a mistake in your registry settings.
It should look something like this...
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
"The_name_of_your_Registrator_Viewer.exe"=dword:00002af9
That was the problem, working fine now. Thank you for your kind assistance, it is appreciated!!
Thank you for this 👍 I have not used registrator viewer in a long time, low & behold google maps was not working within it but now thanks to the original op & this thread, its now all working perfectly, in-fact so much better now than before (as I had loads of pop ups) 😎
Video is playing fine, but Google Maps isn't picking up on my route ?
This is a long thread with a lot of solutions.. Start with... is your Registrator Viewer up to date with versions mentioned in this thread?
Sorry, yes. 6.0.0.22c .
Obviously not sure what I'm supposed to see.... expecting my route to be displayed on GMaps ?
OK, that will be sad..... But will explain the issue. Doesn't seem that there are any viewers that can process the Garmin GPS data
Have tried the demo. FAQ reads as follows :
I’ve had the opportunity to examine Garmin Dashcam movies in a binary file editors as well as a couple of movie player apps. I was not able to locate the GPS tag information in the file. I’m not surprised — Garmin is good at hiding and encoding their GPS data. I’d need help from the Garmin engineers to locate and decode the GPS data. Until then there’s not much I can do.
I installed the exe from the first post, and as soon as I ran it, my PC started playing a "warning your PC has been infected" sound clip, and pop ups galore. I managed to get that squared away, and read back to page 8 where others have posted cleaned up versions that don't populate ads from rogue sites. I also added the various domains to my routers blacklist, so I'm good. But, if I might suggest someone either delete the original ad-loaded version from the original post, or replace it with the stripped version, I think it may help keep noobs like me from pissing their pants.
