Sabe
- Oct 6, 2012
- Finland
- G90, GT300W, Mobius A, C
jokiin said:The USB software only runs under winxp 32 bit
Yes, i do all this kind of work with xp.
Sabe said:jokiin said:The USB software only runs under winxp 32 bit
Unfortunately the software option does not work in my camera...In spite of using it in the menu 🙁jokiin said:That start up problem is common with diesels, we recently added a programmable start up delay as a menu option specifically to address this
Mantom said:Unfortunately the software option does not work in my camera...In spite of using it in the menu 🙁jokiin said:That start up problem is common with diesels, we recently added a programmable start up delay as a menu option specifically to address this
Thauleu said:I got this issue with my GS1000 (GPS).
It worked quite good for almost a year, but last months it hasn't been working at all. And if it do work, its not accurate at all.
So I tried to update by USB, but had a few troubles so I tried by using the micro SD card. Result; the cam doesnt start. Well, it starts up with the blue light (and a new, fancy song) but thats it. If I press the ON button, it does it again, and when I press a button it sometimes makes a "switching between sites" noise, not sure what to call that last one. And yes, the screen stays black - all the time.
Tried reset, older firmware, removed firmware from sd card.
Am I missing something?
Sabe said:Thauleu said:I got this issue with my GS1000 (GPS).
1. Did you backup your original firmware, and have you tried that?
2. What/where was this unlucky firmware you used?
Thauleu said:1. I never found the firmware when I connected to it, so no.. Unfortunatly, which I should have done.
2. 2.0.3 or something, that I followed on this link http://dashcamtalk.com/gs1000/#Blue_Menu_USB_Firmware
Sabe said:Thauleu said:1. I never found the firmware when I connected to it, so no.. Unfortunatly, which I should have done.
Sorry, blue menu is out of my expertise.
But seems that there is not so many fw's available if it is original blue menu.
Thauleu said:But is there nothing to do?
Because after I start it, it seems like it shuts down. But when I press the power button it makes a noise, like its already on?
Feel kind of desperate now.
JonBOY26 said:Hey peoples,
I recently decided to get my first dashcam and found this site a great help. After weighing up the options I decided on a GS1000. I purchased my cam through e-Prance (in June 2013) as e-Prance was a recommended seller and I wanted to try make sure I got a genuine orange menu unit.
The cam arrived and is indeed an orange menu, and I suspect it is a 'new' orange menu given the firmware version. I think the firmware version reads 'SM5E5HGB.130509.V1' however the font isn't the best choice when it comes to distinguishing between 'S' and '5'. Can somebody please check the image I've uploaded and confirm whether i've read that correctly?
Assuming the firmware is SM5...., I'm assuming that indicates the cam is a 'new orange menu' unit, as the firmwares for these new units include versions 4.35 and above. With that in mind, what is the latest firmware version circulating for the 'new orange menu' unit? I'm keen to know whether anybody is running anything newer than this.
Thanks!
Syntra said:I'm in the same boat, just got my GS1000 from Aliexpress the other day but can't find any info on this firmware. Anyone?
Sabe said:There is two possibilities, unit can be broken or you have loaded wrong firmware.
Since you don't know which firmware you had i think only option is to try some other firmware.
One thing you could do is open camera and find out is it ambarella or novatek chip board, that might narrow your search.
You don't have anything to lose, so maybe you just try _any_ blue menu firmware by chance...
Google found one fw from dx.com.
Thauleu said:UPDATE: It is Ambarella. Any more facts I can aquire?[/b]
Sabe said:One more would be necessary, find out is it new blue menu or old blue menu unit, firmwares are different.
Do you have link to place where you bought it?
Thauleu said:Uhm, not sure. Maybe it was the latest firmware? The new blue maybe? Just a guess.
