SteveJ
- Jun 17, 2014
- Hertfordshire, UK
- United Kingdom
- Viofo A129 Pro Duo.
Apology accepted.
You certainly have a very strange way of expressing yourself....... the question regarding confirmation that the 12v socket turns off with the car ignition was perfectly valid as not all cars work this way. On my car I have two 12v sockets, one stays active even with the ignition off and the symptoms you stated certainly made this a possibility. How can you explain that removing the camera power plug from the socket makes the camera power down correctly but leaving the plug connected and switching off the ignition does not.
Apology accepted.
And the "ANSWER" to your (non-existent) original problem is....?😵I "KNOW" the "ANSWER"! I've been posing this issue just to see how many tech savvy people are here. Do you believe that this is within the realm of being somewhat fair?
EST is -5 hrs from GMT. So you need -5 here, but then you probably already "KNOW" that!😛
So your questions are not asking for help, they are some sort of test? That is not how forums work, you either need help or you dont, if you dont then why waste peoples time?I "KNOW" the "ANSWER"! I've been posing this issue just to see how many tech savvy people are here. Do you believe that this is within the realm of being somewhat fair?
It's always a 24hour clock - used for the date/time stamp on the recordings.To be honest, I did not. Thank you very much. In this respect, setting the value at +5 will keep me on a 12 or 24 hour clock, or is a 24 hour clock standard?
He probably already knows that, it was a test.It's always a 24hour clock - used for the date/time stamp on the recordings.
My apologies, in future would it be possible for you to state up front which of your posts are genuine questions that you require an answer to and which ones are test questions that you already know the answer to.No, I specifically stated that I did not know.
I edited my post thinking the first sentence was a little unfair but now I am not so sure!
As stated earlier, 'WE cannot divulge trade secrets".
