WalterBiH
- Dec 12, 2013
- Melbourne
- Australia
- Mini 0806, Mini 0801, Kaiser Baas RoadRecorder, GS9000 (RIP)
Today I received my 0806 from Gear Best (pre-ordered on 30/01/2015).
At first I was very happy as it was clearly 2nd batch (but still in old packaging ), included tidy clips, screws, latest firmware etc...
GPS locked very quickly (under a minute). After playing with it for a while, I proceeded to install it in the car. This is where problems started. As I'm in Australia, I decided to mount it on a left hand side. This meant that I had to flip the image and rotate camera (this is improvement compared to my 0801). After I did this, GPS was no longer recognized. It wasn't just not locking, but icon was missing and green light was OFF (ie. no hardware detected). I put camera in 0801 mount and still no GPS hardware detected. Then I rotated camera back and GPS icon came ON when camera was in furthest possible position. I tried the same thing in 0806 mount, and it only worked in this single position. Clearly the issue was with the camera.
Not wanting to send it back to Gear Best (high cost from AUS) I bit a bullet and started disassembling (using instructions by @Mtz).
I found that camera was very poorly assembled. The wire was pinched by the camera body and stripped.
However, that wasn't the actual problem. GPS wire came off PCB terminal (RX).
I completely disassembled the camera and re-soldered the wire.
Now camera is working again 🙂
I got very quick GPS lock even indoors (pictures were taken inside the house) and everything works through all positions. It is now installed in the car (alongside trusty 0801) and will be comparing the two after tomorrows drive to/from work.
So if you are having GPS problems (especially after rotating the camera) - beware - wiring might be damaged due to poor wire routing. I thought @Rayman.Chan said that this was fixed on production line by re-training workers?
