Mobius Maxi F1.5 2.7k
Likes
6
Estonia
Mobius
In addition to Wi-Fi, the Maxi may also support external GPS at some stage later in development. It was in the early FW that I tested, although no GPS hardware was available to use with it, so it has been disabled for now.
So that means, that in future hopefully we see also some external GPS for this? Would be good option to get also speed info for video :)
Thinking to buy this to replace my old first generation mobius :D
TonyM
TonyM
Likes
1,295
York, England
B1W, A119, A129 Duo, Mobius 1 & Maxi
Yes, GPS is a possible future option with the Maxi. I do not know whether it will be able to embed speed info into the video.
dirkzelf
Likes
527
Netherlands
Wait, what? Wifi? On the Maxi?
dirkzelf
Likes
527
Netherlands
The Maxi has a Wi-Fi antenna. It is currently disabled, awaiting an app to work with it.
That cool, but if it works as "good" ((n)) as some of my other cams with wifi, then I don't need another "feature" sitting in the way of other features.... Nevertheless if it does work properly, it would be great....!!
TonyM
TonyM
Likes
1,295
York, England
I'm not concerned so much about the rear RED LED, I'm more concerned about the big glowing circle, especially in the pitch dark rural conditions I so often find myself in.
I shall be testing a new FW soon which has independent toggles for the rear LED and the circle LED :)
TonyM
TonyM
Likes
1,295
York, England
I did try driving with all the LEDs turned off and just the beep alert to indicate that the recording had started - I didn't like it. I actually unplugged and restarted it to be sure it was working. I much prefer a continuous LED notification to confirm that it's still alive!
Likes
Hi. Can I ask why WiFi is not I included as standard? Eg if your fitting this to rear screen under headliner, it's difficult to access SD. Surely as a dash cam in this era they would have included WiFi?
TonyM
TonyM
Likes
1,295
York, England
The Maxi hardware has Wi-Fi capability. The companion app is still to be developed.
TonyM
TonyM
Likes
1,295
York, England
Thanks Tony
Just a general question. what lens are available, and if there are a few different types what would you recommend?
Maxi is currently available with two lenses:
Lens A F2.8 135deg FOV - Maxi A
Lens B F1.5 150deg FOV - Maxi B
I have only used Lens B so far on a Maxi, and being much faster at F1.5 it is the recommended lens for dashcam use.
I should have a Lens A Maxi for testing and comparison soon.
TonyM
TonyM
Likes
1,295
York, England
This is my Mobius Maxi installed as a rear camera, alongside a Mobius 1 with 6mm telephoto lens. The red notification LED on both cameras is about the same brightness when viewed through the rear view mirror.
I am trialling a new FW that allows users to turn on/off the rear LED and circle LED independently, which should be released soon.
Likes
Thanks Tony appreciate the information. What have you used to attach the camerss to the rear of your window/headliner? Regards
TonyM
TonyM
Likes
1,295
York, England
What have you used to attach the cameras to the rear of your window/headliner? Regards
I am fortunate - my car has just the right angle that I can stick the mount cradles directly to the rear window surround with VHB tape.
I found the 150deg FOV of the Maxi B lens is just right for this application, with just a little of the car visible in each corner of the view to provide context.
Lola
Likes
431
Maryland
Mobius
A peek inside the Mobius Maxi (pre-release sample).
The case is held together with 2No small screws at the front of the case, and two lugs at the rear of the case. The lens holder sits within the split barrel opening at the front of the case. This will make it much easier to accommodate any third party lenses than the Mobius 1, where some lenses would clash with the case. Also note that the FRP lens holder has a set screw for easy focus adjustment and lens replacement. The Maxi comes with a 950mAh battery, which is enough for 140 minutes at 2.7k 30fps or 100 minutes at 1080p 60fps.
Beneath the battery is the PCB. The lens ribbon cable connects to both the PCB and the lens module with a socket and clamping bar, similar in design to the Mobius 1 and Mobius 2. Note that the battery connector is smaller than that on the M1 and M2. It is understood to be the same as that used in the Mobius Mini. At the top of the case you can see an antenna for the WiFi function, which is not yet enabled on the Maxi.
Seeing battery in case makes me think there is plenty of room for a Capacitor, so I don't foresee them having any problems with completing this part of the project.
@TonyM . However I do have another question Tony, What is the distance between the Maxi's lens mount screw holes into the ribbon housing with the B lens which should be the same for both lens types, please don't tell me its 18mm like on the Mobius 1, They are almost impossible to find!!
Harsh Mobius Maxi 15
Rocketvapor Mobius Maxi 10
TonyM Mobius Maxi 1
TonyM Mobius Maxi 121
Similar threads
