Today was dam cold and I noticed that my mobius didn't start,
But I might have found why, it seems that when I crank the engine the cig lighter socket provide less power in order to help the car start up.
If my car starts right up, so do my mobiuses
This seems to be a plausible explanation for this but I did some casual testing of this theory today and got different results.
After my vehicle had started at 6 degrees Fahrenheit and I apparently had full voltage at the 12v cigar outlet, unplugging and replugging my super-capped Mobius would give me a RED flash three times but would still not start. As before, it seems to require perhaps sixty or more seconds of being plugged in at full voltage until it will boot up properly. FWIW, my vehicle has a healthy over-sized battery.
if you try it with a battery and it starts up normally under these conditions then the problems for capacitors is firmware addressable
The option was first introduced in firmware v2.29 so you'll have to use the (inaccurate?) 'B' setting or adjust the colors manually if you prefer to use a previous firmware version with the 'C' lens.Hi @Isoprop
Is there a reason why Lens 'C' option is available only for FW 2.xx?
So, although I haven't yet had the opportunity to test the voltage at the 12V ACC outlet in my vehicle during start-up as promised yesterday, I can confirm that the issue regarding the Mobius (w/super-capacitor) failure to fully boot up in sub-zero temperatures during start-up has nothing to do with lower vehicle battery voltages during hard cold cranking. (at least for me)
This morning when I got up it was -3 degrees Fahrenheit. By the time I got out to my vehicle it was a bit warmer, around +6 degrees F. Before I started my vehicle I unplugged the Mobius USB cable from the (Anker 24W) 12v adapter plugged into the socket. After starting my truck and waiting awhile until I was sure that everything was up and running properly, I plugged the Mobius back into the USB power supply at the 12V ACC socket. The camera gave the usual 3 red flashes on the rear LED and then nothing. I waited perhaps 10 seconds and tried it again. Once again, three red flashes and then nothing. As before, it appears that certain components on the Mobius circuit board require at least sixty seconds or more of power to come up to whatever critical internal temperature they require to complete the boot-up process.
Mine was covered in snow and wouldn't even flash upon start up (maybe I missed it) , let's hope for a firmware fix !!!!!!![]()
The cold starting problem can't be fixed by firmware. Keep in mind that the Mobius is not a military grade cameraMine was covered in snow and wouldn't even flash upon start up (maybe I missed it) , let's hope for a firmware fix !!!!!!![]()
The cold starting problem can't be fixed by firmware. Keep in mind that the Mobius is not a military grade camera. The operating ambient temperature of the DSP is specified as min.-10°C (14°F), so if your Mobius works in much colder environments you should consider yourself lucky.
In addition, all passive components have tolerances, usually 5% or 10%, and a combination of the differences may also lead to one camera performing differently than another. Under normal conditions these tolerances can be ignored, but they may affect how your camera performs when you operate it beyond it's limit.
Ah, so the specs are pretty accurateIsoprop, thanks for the information in this post. I wasn't previously aware of the exact low temperature spec of the DSP but this confirms my experience quite accurately. In one of my earliest posts about this issue back on January 10th. I said, "Up until this past week the Mobius has performed admirably in the cold weather and from what I can tell so far, the problem with a failed start of the camera only begins when the temps fall to 15 degrees F and below."
Hey guys. Been away for a while. My mobious on battery has been running flawlessly for the best part of a year now.
So now I feel it's time to add some to. The other vehicles. Three came in the mail the other day. Now I need to card them up. Looking for 16gb. What is the latest best card for the Mobious. Good picture not to much money.
Thanks for any help.
