Bungus
- Sep 10, 2014
- Burnaby, BC
- Canada
- 2 x Mobius, A, C2. 1 x Toguard CE685
Looks like C lens set narrow will be ideal.
So as i mentioned earlier that a Lens C with Narrow settings can easily replace the Lens A which is a pretty sharp lens but not good in low light, where are the lens C with capable low light lens with narrow settings can work wonders culminating the benefit to work in low light at night at the same time be tack sharp compared to the Lens B or wider angle of Lens C.
Mobius C by night in the rear window. Lens type set to B!
Thank you..However in my case, the camera starts auto record correctly if I connect to the same power source with a shorter cable. It has problem only with the 10 metre cable. I tried with both v2 (lens B) and v3 (lens C) cameras. Both behaved the same way.
I had the same feeling...the B lens pics look like they're out of focus
buildings have more details on the C and also the focus looks better. But this could be a problem of my B lens, I never adjusted it's focus.
I'll try, but I can't promise it will be this week... too busy at workIt be great to see comparisons between standard Lens A and Lens C with narrow settings.
Maybe someone with both lenses could make a comparison. I'm rather pressed for time at present. Otherwise, I may be able to make a short comparison clip next week.@Isoprop which is better the A on wide or the C on narrow? Will the new C lens settings when released, change anything? Any cropping on either, which run full sensor?
I've read that the Mobius doesn't have good night view? Is this true?
My opinion is that the Mobius performs very good at night for the price you're paying for it.I've read that the Mobius doesn't have good night view? Is this true?
Ah ok!Up to 32gb the cards use FAT32, over that the specifications call for exFAT
No. See...I've read that the Mobius doesn't have good night view? Is this true?
Right they do. But does the inbuilt formatter formats through exfat? Or will the cam recognize the 64gb card if formatted via external app converting it to fat32?I thought they had their own formatter built into the GUI
