mcaf123
- Dec 8, 2013
- Manchester
- United Kingdom
- SG9663DC
As I understood from my tests, with latest v1.02.04 FW there has been a BDP values adjustments / calibrations. Maybe this causing an issues with logo freeze and lock up ?BDP must be causing an issue. Since I turned mine off I've not had any issues related to shutdown or freezing, just the rear camera not recording at all. I believe @Dionic90 also has his off with no similar issues
Check your rear sd card, i bet it went into read mode only.Still having parking mode issues. When I checked the rear camera after turning on the ignition all I saw is the red recording numbers but all set to zero. Then when I tried to check the footage of the rear camera it decided to switch to showing the live stream of the rear cam and became unresponsive so I had to pull the plug. When I finally managed to check the footage it seems the rear camera hasn't been recording for the last 2 days.... Almost exactly to 48 hours which could be a coincidence
Kim, i had the same issues, lock ups all the time, i tough it is the BDP, so i disabled it (power the cam trough the cig lighter), and again lock ups. Than i changed the sd cards and the lock ups stopped. I used the cig lighter power for few days to see how it goes before hardwire it again, and since than no lock ups, not a single one. I dont know what kind of sd cards you have, but for me that made the difference.
Another thing I noticed. It had several Gsensor files on the front camera, but none on the rear camera. Is there a Gsensor in each camera or is it only in the main unit?
When g-sensor is triggered both cameras should record in park and drive mode. If someone backs into me in a parking lot and hits my rear bumper trigging record. Not having the rear record does nothing for me.
AgreeWhen g-sensor is triggered both cameras should record in park and drive mode. If someone backs into me in a parking lot and hits my rear bumper trigging record. Not having the rear record does nothing for me.
I didn't know what MLC/TLC meant in reference to memory cards, so I did some research and found the below information. I hope this helps others as well.
NAND flash memory can be sub-divided into 3 broad categories SLC, MLC and TLC.
SLC is an abbreviation of 'Single-Level Cell':
SLC memory stores one bit in each cell, leading to faster transfer speeds, lower power consumption and higher cell endurance. The only disadvantage of Single-Level Cell is the manufacturing cost per MB, meaning that the SLC flash technology is used in high-performance memory cards where speed and reliability are important.
MLC is an abbreviation of 'Multi-level Cell':
MLC memory stores two bits in each cell. By storing more bits per cell, a Multi-Level Cell memory card will achieve slower transfer speeds, higher power consumption and lower cell endurance than a Single-Level Cell memory card. The advantage of Multi-Level Cell memory is the lower manufacturing cost. MLC flash technology is used mostly in standard consumer memory devices.
TLC is an abbreviation of 'Triple-level Cell':
TLC memory stores three bits in each cell. By storing even more bits per cell, a Triple-level Cell memory card will achieve slower transfer speeds, higher error rates and lower cell endurance than both Multi-level Cell and Single-level Cell memory cards. The advantages of Triple-level Cell memory are that the memory chip will be physically smaller than SLC and MLC chips for a given memory capacity, it requires less power to operate than MLC memory and is cheaper to produce. TLC flash technology is used mostly in low-end memory devices where speed and reliability are not important.
