Deleted member 46308
- Feb 19, 2018
Welcome to DCT ironchefff 🙂
I signed up to say that I thoroughly enjoy and look forward to your blog posts. It shows the level of care and hard work that you've put into your product.
I don't have much to contribute in terms of suggestions as I haven't owned a dashcam before but the Joovuu X might be the first one that I try. I look forward to more news, updates and reviews. Keep up the good work!
The more you see from @kamkar1, @Padwanjoe the better this camera is looking 🙂Hi @ironchefff
Firstly, welcome to the forum. Secondly, i'm glad you look forward to them, it really means a lot when someone takes the time to read them and it seems to have an impact on them.
I started the blog because there were quite a lot of misconceptions, reality vs perceived reality, and also because it is actually quite an interesting world. Again, thank you for the encouragement and hopefully we can turn you into a sale...pre-orders go live today....
Dan
yeah it either needs a bend in the shaft to allow more movement or an angled base...........
the challenge I've seen from the shorter ones is they don't have enough adjustment to compensate for the windscreen angle and end up pointing too far down
What is the maximum resolution the camera actually records at? The pre-order page states 2.5k (which would suggest 2560x1440) but the screenshots and videos posted so far are no higher than 2560x1080.
Which is it?
If I got this right, the GPS will be external, and it'll arrive later, need more production time, right? Via which port will it connect, inside the USB power cord?
Does it have automatic shutdown, low voltage setting? Does the USB power cord feed 5V or 12V power? Does it split for always on parking mode BATT wire and ACC+ wire?
What does microSD OTG mean? On The Go, how is it relevant to a microSD card?
Please don't force ****ty and small sized microSD cards by bundling them, it's a waste of time and money for everyone. People know how to buy their own microSD cards.
Working temperature seems a bit low +60C, especially for dash cam environments...
Hi All,
first post for new member,but been lurking as a guest user for awhile.
Anyway just wanted to say placed my order for 2 of these units, going to run this on the cellink B device. Which I am getting shipped to the UK. just wanted to say thanks to everyone posting and input which has helped with the JooVoo. Would like to add if possible if implementing voltage shutdown on the device, It would be nice if this could be disabled for the devices like cellink b and Anypower Alpha which has its own voltage cutoff.
I hope that make sence.
Any recommendations on a capacitor battery for these units?
P.S.
I hope the proximity sensor is going to be better than the blackvue,in the sense when you change the sensor setting it actually works, Blackvue its all or nothing, In fact I had to turn it off in the end, as it was constantly recording.
I went to pre order and unforunatley I can't. www.joovuu-x.com thinks i've registered before which i haven't.
I can log in to Joovuu okay thou, but the same details don't work on Joovuu X.
Tried reset pasoword many times on Joovuu X, and i never get the link to reset it. so stuck?
