- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
- what DB range is the hdr capable of?
- why cannot manufacturers specify the exact gain of the HDR/WDR of their sensor, as it applies to their camera? Rather than leave the potential customer google the sensor & hopefully arrive at the right answer? As it appears that the recorded movie, is not only dependent on the sensor, BUT more? importantly on the Firmware & associated Hardware's ability to produce the desired result. If this was done, then a manufacturer could reliably show that their particular implementation of this Hardware combination produces better movies than others.
- In this modern IT driven environment why isn't an OS of Mac or other supported?
- why is the limit on card size 32gb, rather than something larger?
- When will the gps data be able to be displayed embeded in the movie?
- Other than 1080p30 what other resolutions & frame rates & bit rates is it capable of?
- IF a user can select Exposure compensation: menu selectable -2.0 to 2.0. Why cannot this be done automatically to ensure optimal recording performance? NB This also applies to other dashcams. As I suspect that some do this already.
- Is the angle of the lens in relation to the body, changable? & if so over what range? Whilst the photos suggest this is possible, the specs don't mention it.
- what duration is each movie it creates?
- will a CPL filter & lens cap be available?
The HDR gain or range is hard to specify, you can look at the hardware specs but there are too many variables for numbers to have any real world relevance I think
Mac is supported, I haven't tested the updated Mac version of Registrator Viewer as I don't have a Mac but we're listed as a supported model already, they worked for a few months already to support us in the Windows version so I take it the Mac version will be sorted
64GB 'can' work but is not officially supported, we know 32gGB works fine and that's what we supply with the camera, and recommend
don't have plans to embed the GPS data in the video, not at this stage anyway
1080p30 only, other resolutions suck so we removed them, bit rate is 15mbit/sec
EV is automatic, the adjustments just allow you to add or remove some bias, it's not a manual setting
lens angle is adjustable up and down about 70 degrees (I haven't measured it, this is just by eye), seems to be plenty for everything we've tried
1, 3 or 5 minute selectable, default is 3 minutes
no CPL, the design is not suitable, lens is too close to the window for it to be practical, no lens cap either but we supply a microfibre carry bag with all our cameras
