- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
power magic pro only work with two wire connection, no way to switch modes in the camera
the camera functions change when you turn the car off, can't do this without the correct input
I guess since I mounted the thick one I couldn't see how thick for a comparison. Thank you.Thick on the left, thin on the right. Thick is needed to give a bit more CPL Clearance on certain angle of windows.
What are the features going to be of this kit that's coming pretty soon?
Pw i believe are 12345678, name though ??? probably the strongest signal around must likely something like 9665DC in the name
When you turn on wifi the screen go blank or rather i believe the wifi broadcast name are there along with the PW.
Found it!!When you turn on wifi the screen go blank or rather i believe the wifi broadcast name are there along with the PW.
@jokiin is pretty close. I record 5 minutes segments at medium quality and it takes about ~558MB per segment. You can calculate it out from there. Here's a sample of the file sizes.How long can you record with 128 vs 256 on the highest settings?
