Paul Iddon
- Apr 5, 2016
- Preston
- United Kingdom
- Viofo A139 Pro 4K, A129 Pro Duo 4K, A229 Duo 2K, & NB 522GW
Steady on - testing the night time footage...
Id like to see some night footage on dark streets or roads.
The files are available via http, you will need to do a little work to parse the file list to extract the links from the home page before downloading the individual files, but not too difficult.Would it be possible to grab the video files via a web service? I'd like to copy the files to my file server @ home using a script I'll write.
The zigzags I assume you mean? They mark out an area either side of pedestrian crossings as safe zones.
Is the rear cam cable the same as the one for Street Guardian SG9663DC?
That's fantastic news, thank you!The files are available via http, you will need to do a little work to parse the file list to extract the links from the home page before downloading the individual files, but not too difficult.
I installed an a129 today in a 2016 Honda CRV and it was no problem with a regular metal snake.Bamboo is pretty good at transferring the feel of what it is pushing against back to your hand, so you don't tend to poke holes in things, much better than more flexible or heavier things. Must be plenty of alternatives though.Bamboo stick should be great for poking a hole in your roof lining
Here we use the hard plastic yellow tongue that comes from tongue and groove flooring
For most people, it is best not to mount it too high or the wiper wont reach to clear the rain on the outside and the heater wont reach to clear the mist on the inside...I installed an a129 today in a 2016 Honda CRV and it was no problem with a regular metal snake.
I found it much easier to reverse the wire from the suggested way, because the angled connector allowed me to mount the rear camera higher.
The headliner in the vehicle was far too thick to be punctured.
Sent from my SM-G955U using Tapatalk
J | Viofo A129 Duo Parking Mode Problem - Please Help | A129 / 129 Duo | 11 | |
W | Saumsung MicroSD + Viofo A129 Duo | A129 / 129 Duo | 4 | |
Y | Installing VIOFO A129 DUO in 2018 Nissan Murano | A129 / 129 Duo | 4 | |
M | Viofo A129 Duo questions | A129 / 129 Duo | 4 | |
D | Viofo A129 Duo parking mode is bad | A129 / 129 Duo | 18 |
