Paul Iddon
- Apr 5, 2016
- Preston
- United Kingdom
- Viofo A139 Pro 4K, A129 Pro Duo 4K, A229 Duo 2K, & NB 522GW
I will monitor it further...
Paul.
Paul.
As promised.Good question. I was going to post the video to show @TonyM what happens when the buttons are pressed.... now I just have to find the correct video! Stay tuned.
On iPhone 7 Plus, when entering the application, it gives an error.a iPhone 8 IOS 15+
And with A139 it works fine !!
iOS 15.1What IOS is your iPhone running?
Did you manage to get it to stick?Mine fell of in England 3 times...
Paul.
It stayed on after the first time for a week maybe, then fell again. Then a couple of days later.Did you manage to get it to stick?
I used the supplied sticky pad and that didn’t last the day!
It fell off the windscreen within hours.
I have just put a 3M sticky on it so tomorrow will be the test.
If you used the provided spare sticky pad like I did as well, it is going to fall again soon. Those pads didn't seem to have a name brand on them unlike the ones from the other viofo products where they where using the good 3M pads.The T130 no longer sticks to the windscreen. I suspected the pad was not a 3M due to no labelling which is not a problem but if you are on to a good thing then stick to it! (Like how I did that lol)
The temperature is nowhere near what it will get to in Australia so I am expecting many will have this issue.
I am placing the backup sticky pad on it. Hopefully, it will last longer. I did make sure the windscreen was cleaned before I had installed it the first time. Isopropolene and a warm day... in the sun 18 degrees type of warm.
In my case the sticky pad stayed in the windscreen and the camera was hanging with the mount attached to it.Hi @runtohell121 and @Paul Iddon,
Can you confirm please if only the dashcam fell without the mount still sticky on the windscreen or the dashcam fell with the mount together?
