70mai Firmware Update (changing from Chinese to English)
Just cut first 32 bytes from factory sdcardv.bin file with a hex editor (eg. HxD). It should start with MCR2 instead of AITS. Flash that to eeprom.
Hello everyone. I find myself the same problem, you could indicate the chip to be reprogrammed.
Thank you
You could tell me the function of the third key, it is located near power.
I would like to know that as well. You can press it from outside, there is a hole up to the power button. And another hole for microphone half between power button and lens.
Maybe some recovery flashing without desolder, but i found no tools no documentation.
How could I establish which version (CN/EN/Int) of 70Mai I have.
I don't want to brick my cam by f/w version misuse.
Sorry if duplicate the question but honestly I've went through posts in the forum and I have still hesitation about the cam version...
on CN version "70 迈":
on EN, INT version "70MAI":
спасибо большое друг!
Tак что если у меня есть надпись на латинице
- Mогу загрузить новую английскую прошивку
никаких сюрпризов не будет ...
поздравления
Marek
да, все верно
Hello
It turned out to change the voice control in the Chinese version.
So..
FIRMWARE for Chinese Version (CN)
[with English voice acting and English voice control]
v.1.0.6eu
Сhangelog:
  • Optimized recorder G-sensor algorithm
  • Increase the recorder settings to save the save function
  • Solve the problem that some models of the fire recorder turn on the red light
Eng commands:
  • Take picture
  • Record video
  • Record without sound
  • Record with sound
  • Turn off Wi-Fi
  • Turn on Wi-Fi
SD_CarDV_1.0.6_(for CN version)_ENG VOICE AND CONTROL.zip
Thank you. Works like a charm.
Hi @lisabon_Q3
Firmware 1.0.8 EU for International version of camera.
Thanks, works great!
Hi guys!
FIRMWARE for Chinese Version (CN) MIDRIVE D01 (NOT D06 1S MODEL)
v.1.0.8 eu
Take picture
  • Record video
  • Record with sound
  • Turn off Wi-Fi
  • Turn on Wi-Fi
  1. Take out TF card and insert it to your computer (or using a USB converter to connect computer).
  2. Download the file named SD_CardDV.bin to the root directory of TF card.
  3. Insert the TF card and keep the power cable is charging.
  4. The device will automatically upgrade. DO NOT discharge until the voice prompt “Update succeeded” is over.
SD_CarDV_1.0.8eu_(for CN version)_ENG VOICE AND CONTROL.zip
Thanks for the update! Voice control works 10% of occasions for me.
Hi guys!
Thank you for your disinterested work ... it's a very big value.
Gracias por su trabajo desinteresado ... es un valor muy grande.
FIRMWARE pour la version chinoise (CN)
avec voix en anglais v.1.0.8 eu
un grand merci lisabon_Q3,firmware installé fonctionne bien.
hello,
is there any update so you can record event by holding the button, not the voice command?
because voice command during driving is not working, everything is too loud and camera doesnt understand me.
so i would like to record the event by pressing the button
hello,
because voice command during driving is not working, everything is too loud and camera doesn't understand me.
so I would like to record the event by pressing the button
The event only triggered during an accident.
Hi guys!
v.1.0.8 eu
Take picture
  • Record video
  • Record with sound
  • Turn off Wi-Fi
  • Turn on Wi-Fi
Thank you very much
I've had my 70mai for 18 months and never set it up because I couldn't convert it to english just wanted to say thanks to lisabon_Q3 your work is very much appreciated just upgraded from 1.03cn to 1.08eu.
