Falsificator
- Mar 15, 2014
- Kaliningrad, Russia
- Russian Federation
- Ambarella, Novatek
Yes, it is!Is g-sensor trigger the only parking option?
We can do that, but not sure we add it to the parking mode list!Will low bitrate be available later?
4th character on the number plate has been corrupted on the B2W. There isn't a rain drop in the same place for the A129, but normally they are sufficiently out of focus that it can see through the drop so the characters are still there and readable, just a bit blurred/low contrast. Of course it does depend on the size of the drops, too big and the B2W will win because it can still see a lot of the image while the A129 can't, but that is not a problem if you use your wipers.I was curious to see whether light raindrops on my windscreen are more or less noticeable with the B2W than my A129. Measured horizontally, the B2W's lens is about 16cm from the windscreen, whereas the compact wedge-style A129's lens is just under 7cm from the screen. As expected, there is a visible difference. The B2W renders raindrops as small highlights that are almost in focus. On the A129 these highlights are larger but less well-defined. I'm not sure whether one is better than the other. Perhaps larger blurred dots are more likely than smaller discrete ones to obscure important details? I don't see much difference in the dashboard reflection between the two cameras.
What is the exact meaning for "choke'?but in areas with a lot more information the camera do choke due to the modest bitrate.
Thanks for your time! And then start to test the dashcam on the road?So, the correct curve is found. It remains to find the correct curvature. Sly this curve is some kind...)
View attachment 47521 View attachment 47522 View attachment 47523 View attachment 47524
Today there will be a field test...And then start to test the dashcam on the road?
But there is no correct answer, and the stock firmware isn't wrong!Gamma curves are also not as simple as they seemed at first.
The curves are non-linear and with the slightest inaccuracy the picture changes extremely much.
But I'm trying...)
This is your personal opinion. I think differently...and the stock firmware isn't wrong!
