- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
yeah text needs to be updated
I just hope that this will have the 2 types of QA used.
1. Quality parts and design that eliminates most failures from the start. (I have no doubts here.)
2. At least 2 people dedicated to QA. One who looks at every part for defects and the circuit board to verify good soldering by the human element (which causes most problems) and one who tests each cam as an assembly for at least 24 hours with sd cards to prove the focus and recording capability. There could probably be software developed to verify constant recording with only a human needing to verify correct focus. Looking at the date marks and file size from each recording to prove recording happened should be easy to automate.
If more manufacturers followed this testing each individual cam we would not have the fiascos of some series of cams having horrible failure rates and needing DIY solutions. I would gladly pay an extra $2 to know the cam will work correctly compared to wondering if it would work or not out of the box as a recent cam introduction has had to many problems.
100% tested and working is a great sales pitch.
Will this have a metal cmos holder? After the mobius went to a FRP cmos holder and video went out of focus this is a concern.
What kind of lens covers will be available? Will one be made with a filter to reduce glare?
Thanks for answer Dan.
These GPS I have fixed was more than 2 years old, but less 4 years. Some people just like to keep thing and think it’s an easy fix.
I have been reading in this forum, the last couple of month and I really like you product on paper.
1. Small.
2. No screen. Less to fail.
3. Capacitors. No battery to get cooked.
4. The fact you got some experience, what not working in a camera as dealer and try to build a better camera with people from inside and outside of China.
5. Dealer in USA.
Ps: Hope the microphone is sensitive enough to pick up a voice from a cop, if you get stopped.
I will keep an eye on this product and mostly gonna buy it.
@ country I’m ready to pay $5 extra for quality and test.
Will the PC program be able to do all that the APP can do? Some people may have laptops or windows tablets.
As far as USB ports go, I prefer mini over micro any day, twice on Sunday.
Mini is much stable compared to micro port/plug.
One of my dashcams micro USB port isn't snug enough.
Never had any issue with mini though but I think as long as the micro plug and port both are of decent quality, it should be okay.
a good quality Micro USB plug and socket is no issue, a lot of products don't use good quality plugs and sockets, that's an issue
Am I correct in thinking that SD card recording times would be about half what they are now using the highest resolution possible?
I would suggest having 3 adapters available for the micro USB plugin. 1 going up. 1 going down. 1 going to the side not having the HDMI port. That way whatever orientation the cam is placed in hooking up the USB cable will be easy. The adapter would also take any wear from unplugging and plugging in the cable instead of the cam itself. I would expect these to be extra cost accessories not standard equipment.
Looking at my current car and truck I barely have room to mount a mobius sized cam above my rear view mirror. Having an angled usb port (or one on the top of the cam) would make fitting a cam much easier and would be a more compact solution.
I see a minor design flaw.
The event button on the side would be in the wrong location for me. In the USA we drive on the other side of the road. With the cam right side up finding that button would be awkward. Installing the cam upside down could place it in a less than desirable spot. Maybe you will have a mounting bracket that allows the cam to be mounted either way in a car like the mobius does?
To me having the event button on top makes more sense. Of course, everyone else could disagree with this perspective. Maybe it is because I am planning on mounting a dash cam on top of my double jointed rear view mirror stalk. Pushing a button on the side could misalign the cam from where it should be aimed.
Lol... we drive on left here? No wonder other drivers were honking at me.It seems to me that when mounted as a dash cam, pinching the JooVuu-X between one's thumb and index finger would easily operate the event button no matter which side of the camera it is on regardless of whether you are in a left or right hand drive vehicle.
@country_hick, I for one am very grateful that you have informed Dan that we here in the US drive on the opposite side of the road than in the UK. Heaven only knows what might have happened otherwise.![]()
Don't need an event button as long as a tap on the back will lock the files, be nice if the G-sensor ignored vertical G (ie potholes) for event triggering...I see a minor design flaw.
Yes, tap on the back = file lock, tap on the right side = photo, tap on the left side = marker (clicking on a marker in the viewer software takes you to the exact spot, as used on google maps).G-sensor angle specific triggers is an interesting idea
Well it may need some calibration to match the car's suspension, but I find a tap on the back of the mini 0806 to record a clip much easier than using the buttons! Little buttons and driving don't go well together.For anyone driving on anything other than pristine urban roads in a perfect genteel environment, this is an absurd idea.
UK drives the left lane,but after install the camera with car suction cup mount,the power button was also left side.And dash camera need to leave space for drivers to press easily..It shall not be a problem,our shop owner told USA market is big and design that on purpose.It seems to me that when mounted as a dash cam, pinching the JooVuu-X between one's thumb and index finger would easily operate the event button no matter which side of the camera it is on regardless of whether you are in a left or right hand drive vehicle.
Finger tap on the back (cancel G-sensor) will lock the files? Do you mean this?Then it is too easily lock all files and made the card full and makes the camera finally looks like missing files.Don't need an event button as long as a tap on the back will lock the files, be nice if the G-sensor ignored vertical G (ie potholes) for event triggering...
A finger tap on the back of most cameras with a G-sensor should lock the current file. The G-Sensor detects shocks, doesn't matter if it is a shock from a finger or from another vehicle. If it ignores vertical G force then you can set it at a reasonable sensitivity for finger operation.Finger tap on the back (cancel G-sensor) will lock the files? Do you mean this?Then it is too easily lock all files and made the card full and makes the camera finally looks like missing files.
