May be worth you looking at this:I understand that.
Im from really hot country, and i want to power the camera when its on parking, that why i need a realy durable lens mount.
Tomorrow will be a sunny day, I will test for more than 4-5 hours.Anyone try continuously running the A119 for more than 4 or 5 hours and see if there's any heat issues?
No need for metal if there are no problems with actual lens because are good quality. In my previous day test with 4 cameras only XiaoYi had this problem.Why viofo dosent make metal lens mount?
You are assuming that a "metal" lens mount is the best!Why viofo dosent make metal lens mount?
you can suggest it to the devolopers.
We confirmed the little blue issue, the weather is better now, so we can improve it soon.Also my A119 sample is a little blue, you can see this in my previous 4 cameras comparisons from here. I reported this but at the time when actual firmware was released in China was bad weather so not enough good time for fine tuning by Viofo developers.
The production version will use the metal lens holder, seems most of user prefer metal version.Tomorrow will be a sunny day, I will test for more than 4-5 hours.
enjoy,
Mtz
No problem for the current version, normally we need do heating testing for every new product, if there is focus issue under heat, this is already solved.Hi Bill @viofo : you made the decision to use metal lens holder based only on users preference or you tested the current lens mount and found out it has focus problems under heat?
