BowtomePhil
I am on the new firmware and mine has frozen twice. I am turning off the low res recording and just doing hi res and going to leave my camera on all day to see if it freezes (in my house)
Try to clean the rear connection, I had the same problem as you until I clean it with spray.I've had the 522GW installed (hardwired, ignition only) and working perfectly for over about 18 months. I bought the rear camera recently having plucked up the courage to run the cable properly throught the hatch back etc. I thought this would be the difficult bit but seems getting the camera to work reliably is by far the hardest part.
I have had the rear camera showing an image on occasion but most of the time when the camera starts it instantly crashes with the 'recording' icon stuck on 1 second. If I remove the HDMI connection to the rear camera and press the reset button the camera springs back into life and will (so long as I don't plug the rear camera back in) work perfectly again (I appear to be fortunate and haven't experienced the other locking / crashing / chiming issues others have reported).
As soon as I plug the HDMI cable back in the camera will reboot and then crash. If, however, I disconnect the camera using the 'audio jack' style connection at the rear camera end and then restart the camera, the rear image will appear. It will then fail again the next time I cycle the camera (i.e. the next time I start the car).
I thought this might be a poor connection at the rear camera end so have taped up the connection to hold it together - no joy, same result!
This is really frustrating having gone through the effort of running the cable - there is definately an issues here that Nextbase need to acknowledge and resolve.
PS I am using a 32Gb Nextbase card but have ordered a Samsung Evo Plus as advised in an earlier post and will also follow the formatting guidance to see if this makes any difference although I am sceptical.
the card speed is plenty on any brand name card, they may not have done much work in firmware to support memory cards other than their own branded cards, that could be improved in firmware, their bigger issues are related to power, no getting around that with the current hardware thoughWhat I keep remembering is Nextbase themselves, posted somewhere here, that some of their cameras need at least 30mbps and I seem to recall Tiffany posting 50mbps write speed for one high spec camera.
